i think im qualified to be a carpenter now
timaishu
So i went to sears yesterday and bought a new dishwasher.
It was delivered this morning. Started learning myself on how to install it. Looked at the directions and stuff.
I started hooking up all the fittings and got the plumbing worked out. Then had to figure out how to wire it up cause it designed to be hardwired but the wall has an outlet. So I bought a dishwasher 3 prong plug and hooked it up to the washer. At first I though it was broke. I plugged it in and it didnt work. I didnt cross my mind that I plugged it in to the garbage disposal plug. So it wouldnt work till I flipped the switch.
Anyways, I now have the wiring and dishwasher plumbing all in. I then went and turned on the valve things under the sink and no water is coming out. Now the faucet dont work either. So Im going to home depot tomorrow to buy new ones of those.
this.. And what does that have to do with carpentry fatass?? its plumbing.. And how tough is it? SHould take 15 minutes to hook up a Dishwasher ( 30 if you have to add new lines ) ..you bonehead
edit
you also fail at basic electrical
So i tried sliding in the slot. I had my neighbor come over and we took out the faucet. Turns out the valves are good.
I need to mess with the height adjustments as it sits kinda crooked in the dishwasher slot.
You should have hired this guy.....
timaishu
timaishu
San Diego
TMali
