I screwed up!! =[
ck311
This was my first amp install and everything was going well until I went to hook up the power to the amp... got some sparks, so I double checked, and sure enough I hooked up the +/- backwards!! ugh
anyways, I put it in the right way and when turning on the radio the amp doesn't have the power or protect mode on.. Did I just blow the amp? It's the hifonics hfi1500d and it's supposed to have protection against reverse polarity I thought? So should I go to a speaker shop and have them check everything out (probably charge me like $100.. or just try to replace/get a new amp..?
Can't believe I did this =[
Edit: I'm guessing since I saw the sparks it means that everything else to power the amp was ok (car was off), so I would assume this means that I blew the amp and going to the audio shop will just be a waste of time/money?
a simple "this^^^" wouldve sufficed from most of you since i said fuses lol
lol thanks, I'll head out there after a quick shower and check. If it is the fuses, how can I get a replacement, are they common and avail. at Home Depot or something? Sorry for the n00b qs, this is my first install.
Ok, phew. Fuses are all good. I ran the remote power up to the front of the car to the 12v lighter and the amp powered on =]
so that means I have something wrong with the SOEM-T adapter, going to check that out now.
Thanks for your guys help though
ck311
ck311
West Palm, FL
SicAudio
