I need tech info for a sub!!
sorry i cant give you the specs myself...but, if nobody else can, try contacting the manufacturer online and they should be able to give you the info you need. i did it with several manufacturers and have had good results.
good luck and good listening!
there are a few kinds of xtr 15's therer is a xtr15d that is 500 watts rms with a dual 8 ohm vc and there is a xtr15s that is also 500 rms and single 4 ohm vc and the last xtr is the xtr pro 15d that is 1000rms and dual vc
mykeys
URABUS
mykeys
South Prairie, Wa.
jtmoney
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
