- Thread Starter
- #31
Instead of starting a new thread.. I just got my equipment in.. yay! Now,.. I'm going over this PPI 5 channel amp,.. and what it says for settings doesn't match up with what i actually has on the amp to select. There's mainly just one switch I'm not sure about.
Here's the amp buttons:
Now you see where it says [sT] - [4CH] ?
Well, that's a setting that's to select input.. Quoting from the manual: "Input Selector Switch: - Choose ST for single stereo input. This allows the front, rear and subwoofer channels to receive signal from ONLY the FRONT RCA Input. Choose 4CH for 4 Channel Input. This allows for Independent Front and Rear RCA Inputs, and the Subwoofer signal is taken from the Rear Channel Input. Select the 5CH to use all Five channels to use All of the RCA Inputs Independently for Signal Inputs. "
As you see,.. it has Front RCA inputs, Rear RCA Inputs, and SUB RCA Input. (Same as the back of my headunit.)
Here's the problem.. The picture is what my Amp looks like.
It does NOT have the 5CH selection. Just ST and 4CH.
That's not right. The amp should have the 5CH (5 Channel) selection because it's a 5 Channel amp. But it's just not built in, and the manual even says it has this "5CH" selection.
So What to do? Is the amp just going to use 4 channels now?
That's the more major issue.
But there are more issues on what it's supposed to have and what is actually on the amp.
See the Rear Crossover Selector Switch (Says LPF, HPF, and FULL)?
The manual says: "Rear Crossover Selector Switch - Choose to activate the High Pass Crossover, Low Pass Crossover, OR the Band Pass Crossover for the rear channels. Band Pass Cross-over uses the High pass AND Low Pass crossovers simultaneously."
Again.. It doesn't have the "Band Pass Crossover selection here. Just LPF, HPF, and FULL. I can live with this, because it's just a cross-over but still another oddity.
I don't like the fact that it doesn't have the 5 Channel Input Select due to it being a 5 Channel amp //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Any thoughts? I went with PPI due to everyone recommending them due to their quality.. So hope this amp is fine,.. and the buttons somehow work like they are supposed to even though it doesn't have the switches,.. especially to put the input select to 5CH (5 Channel). I can see that being a problem, using 5 speakers, Front RCA's, Rear RCA's, and SUB RCA's.
