i just got a program-- Bass box pro 6
Musto
Alpine+eD = kick ***
anyone have it? i just got it, you enter in all this info and it tells you what kind of box you need to build, it gives the dimentions of all the peices and all that. its cool. im gonna use it to figure a way to fit the 4 12;s in my trunk...anyway...anyone used this before?
Matt
I've heard of it...where did you find it and how much was it???
And I still have that Juggy...I'll let it go for $275 still...do you have a box for a single 10???
Hey man,
Yeah I have had that prog for about a year now and have built 4 boxes off it. I'm sure if you have checked it out you can see it's better than all the other crappy stuff out there heh. Good luck on the box buildin'
NP
hey, some of you guys that have used this--- how do i enter the dimentions of my trunk to tell it how much space i have to work with? i figured out how to add 4 drivers, but im having trouble understanding how everything works, i tryed to read the manual but just get confused. do any f you have a tutorial page or something? or can you type out like a example of the process to use the program? like click on this, enter your subs, click here enter the dimentions, etc...? thanks alot...
Matt
Originally posted by Musto hey, some of you guys that have used this--- how do i enter the dimentions of my trunk to tell it how much space i have to work with? i figured out how to add 4 drivers, but im having trouble understanding how everything works, i tryed to read the manual but just get confused. do any f you have a tutorial page or something? or can you type out like a example of the process to use the program? like click on this, enter your subs, click here enter the dimentions, etc...? thanks alot...
Matt
Well unfortunately it does not work that way =/
1: pick your subs from the list or put in the paramaters yourself.
2: select the type of box shape from the list it gives you on the box shape tab
3: then click suggest button
4: choose your wood thickness
5: once you have chosen your interior volume and your desired qtc lock vb
6: then work out the dimensions of the box to fit your space
It takes time so dont rush it. Just practice with the prog. Good luck and I hope that helps some.
NP //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Under box properties..box design tab.....lock the dimensions you want to keep constant... some will have to change to be optimum. You have to work at it tho... can't just say heres my trunk size and presto a box is designed. I mean if you spent some time looking and figuring with the program theres no reason why you can't figure it out.
WK
Musto
Musto
Hattiesburg MS
Night Pirate
