If it doesnt stick, it was installed incorrectly (insufficiently) in 99% of cases... those are good odds. I dont car eif you followed the steps, you may have not done one of them thoroughly or properly. edead may not be the *stickiest* out there, but it is sticky enough if installed correctly. The only way it wasnt install error is if a bad batch of it came out or some other freak thing happened... very unlikely.Oh the irony.......
Anyways....you shouldn't slam someone when you don't know whether or not they've installed it correctly //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I see no reason to assume that he used it incorrectly.
hey like I said if it works for you great...If it doesnt stick, it was installed incorrectly in 99% of cases... those are good odds. edead may not be the *stickiest* out there, but it is sticky enough if installed correctly. The only way it wasnt install error is if a bad batch of it came out or some other freak thing happened... very unlikely. Again, mine sticks fine...
I bet you'll find a way to f it up...
for now Im done with this $hit..... I will still use the liquid though... I dont think that is going to fall off
Ive installed Raamat, dynamat extreme, edead, and second skin...why is it that the only one that i have problems with is the edead...If it doesnt stick, it was installed incorrectly (insufficiently) in 99% of cases... those are good odds. I dont car eif you followed the steps, you may have not done one of them thoroughly or properly. edead may not be the *stickiest* out there, but it is sticky enough if installed correctly. The only way it wasnt install error is if a bad batch of it came out or some other freak thing happened... very unlikely. If I could come over and do, I would bet ANYONE $1000 that I could get it to stick permanently...
