I got 2 broken x360's for free...
ThatChevyGuy
sue me, its a ford.
One i was told had the RROD, but when i started it up, everything is a go, the controller wont work with this one, and it wont read games. It makes a ticking noise when it starts to read, really loud.
The second one the controller works with it, but it also wont read games.
Any suggestions on how to fix these? Both are from '07
I can fix them, i just pulled them apart and took the drives out.
The lazers went out in the drives. I just need the new drives flashed //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I guess the one that had the RROD is fine ?!
depends on the true reason of the RROD. not all RROD systems have the same issues. the most common issue is the GPU's soldering coming undone which causes the RROD. though there are some RRODs that may have bad memory issues or caps that have burned out or as you mentioned as well that the 360 won't pick up controllers. i wouldn't want a 360 that has no wireless controllers.
like said dump the first one.
if you think you can swap the lasers from the first 360 drive to the other 360 you may end up with a working 360 if you can pull it out of rrod status. though you may have deeper issues with the drive like a PCB board gone bad, which i have seen.
flashing drives is not possible on everyones computer. i can't flash drives so :/
check and see if you can flash the drive but overall i would just send the second 360 to someone who can install and flash a new drive in there to play backups.
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
douglas.leejr
