i am in dire need to find an amp
  • Thread starter Unregistered
  • Start date
  • Replies 2
  • Views 877
  • 1
U
Unregistered
Guest
i need an amp to power my 2 SONY ES XS-L1255G (1200watts each), and im wondering which kind of amp i should purchase, or how many watts the amp should be. thank you.
i have an autotek stealth that i had benched at 1700 watts and it is a massive amp to compete with. i also have a ma audio hc4002 for sale its brand new. i want 150 for the autotek and 500 for the ma audio.
i personaly think that the jbl 1200.1 or maybe the 600.1 should power these fine they are both great amps for the price. look at yahoo stores for them they got the 1200.1 for 300 and the 600.1 for 250. if you go with the 1200 run it at 4 ohms but with the 600.1 run it at 1 ohm you should be able to get enough power from it.
129
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
105
445
343
751
Guest
geonn
    May 12, 2024
Brendon Jenness
    May 11, 2024
