Humming thru my Amp
handyman1355
I have a 2012 chevy cruze . I was attemping to install a small amp to the factory radio/Cd player It sounds fine till I turn the headlights on or hit the brake pedal then I have a fairly loud hummin noise. I ran the power down one side and the input and out put down the other, tried a different ground but nothing has worked. I tapped into the speaker wires that were going thru a large pin connector that has several other wires going thru it, Could the interference be coming from the point where I tapped into the speaker wires? Or do I have a ground problem?
get a headphone to rca cable and see if it does it on a different source like you phone. if still there try jumping the remote straight to the + of the amp and see what you get.
handyman1355
handyman1355
kentucky
CrossoverOre
