hu powering
you kno how theres a positive and negative wire coming from the hu
the negative wire is the ground wire
so when i was testing for voltage i didnt get a reading when i used the negative as a ground wire so i instead touched it to something metal on the car
Yep.
Yep.
Oh?
Isn't the ground supposed to be attached to metal something connected to the vehicle's chassis?
I'm still a bit lost as to what you're needing/asking/trying to tell us....
I think he might be referring to the negative wire of his speaker?
if thats the case, then it looks like you have some bad wiring.
The speakers shouldnt be connected to the chasis.
I think he might be referring to the negative wire of his speaker?if thats the case, then it looks like you have some bad wiring.
yea thats what i was asking if you think it might be bad wiring or somthing f'd p in my hu
each speaker needs both wires from the HU both the Negative and the Positive. You most likely f-ed your HU, but it may have survived. The Negative wire is not the same as the Ground wire.
PESteele
I wang on an 8 in a van
PESteele
annapolis
PESteele
