HU clipping @ 65%?
so what is the difference in setting it at 61/62 or 45/62...if you use a DMM or something to set your amp aren't you still going to get a full power unclipped signal?
He probably has the bass set to high so he has to turn the volume up to make the highs clear enough to hear.But since the bass is so high when he gets to 40 it is distorted not clipped.
Why not be able to use the actual amount of volume allotted? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Lower volume setting would just mean louder @ higher volume with a chance for potential distortion, also a higher gain setting that may allow floor noise, but not always.
Never thought about the floor noise....I will reset my gains with the volume quite a bit higher and see if it makes any difference...only annoyance for me would be turning the volume knob for a longer period of time to get the volume down before I enter the neighborhood (not that bad of an annoyance really)
IDSkoT
Resonating Reticular
IDSkoT
Miami, Florida
Puggsley456
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
