HU clipping @ 65%?
IDSkoT
Resonating Reticular
I think my HU is clipping at 65%
I have a Pioneer DEH-P6900UB.
The thing is, volumes 1-20 are basically garbage and give no real volume. It only starts getting to actual sound at around 25-30, and kinda loud at 35, but by the time it's 40 it's blaring, and I'm pretty sure clipping. The volume goes to 62, and how it is now most of the time I keep it at 37-ish.
But, is that normal? I did the math, it's about 65% @ 40, and I'm pretty sure it's clipping because once it reaches 40 it sounds like absolute garbage. Unless I've been uninformed on HU clipping.
Not sure about that particular model....I have the Premier P-780MP and it still isn't clipping at 45 (that's what number I used to set my gains).
If you're sure it's clipping that early then back it off until it stops clipping and use that number to set your gains...you should still reach full power on your amps...will just be a little sooner on the volume dial.
While I like the sound of the Pioneer HU's I'm not real impressed with their uniformity...(My current P780-MP is not a 4volt preout...it's only a 2volt for some reason...last one I had was...same amps, different gain setting with same DMM...WTF is up with that?)
If you are running the mids and highs off the deck and an amp for the sub then you are probably clipping the signal to the mids and highs trying to overcome the bass.Turn the bass down so its not so loud and you won't need to turn it up as loud.
IDSkoT
IDSkoT
Miami, Florida
Puggsley456
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
