hp difference
Will it feel different probably, will it be better who knows. Whats the torque difference, where is the peak HP made, how much power do each make across the entire RPM range, does the power match up with your driving style...do you live 1/4 mile at a time...
basically, drive both, see how it feels
lol - notice a 5 hp diff? You have quite a sensitive *** to feel that in the seat....30hp diff - yea you'd notice that...unless other factors are different. Like Duece12 said, check the other specs to see how they compare. Are the gears the same? Lot of variables with a generic post. Everything the same other than more hp(and I'd assume torque is more) yes you'll feel it.
Dave
2001 1998 2002 2003
Standard Engine 3L 222hp V6 3L 190hp V6 3.5L 255hpV6 3.5L 255hp V6
Horsepower 222 @ 6400 RPM 190 @ 5600 RPM 255 @ 5800 RPM 255 @ 5800 RPM
Torque 217 @ 4000 RPM 205 @ 4000 RPM 246 @ 4400 RPM 246 @ 4400 RPM
Valves 4 4 4 4
Displacement (cc) 2988 2988 3498 3498
Bore X Stroke (in.) 3.7 X 2.9 3.7 X 2.9 3.8 X 3.2 3.8 X 3.2
Compression Ratio 10:1 10:1 10.4:1 10.3:1
bolded these to make it easier to read
if u want hp go with a mustang not an import too much work for not enough results i got an n/a 557 bbf putting out around 850-900hp show me a NATURALLY ASPIRATED ricer tht can do tht no turbos allowed
don't need thaT MUCH hp. plus i would never buy an american car, only truck/suv. love my japanese whips!
I feel 5hp changes in the same car is when it becomes noticeable, that much hp will make a big difference but if the cars aren't exactly the same its much less noticable
adio
THE STEREOTYPE FIGHTER!!!
adio
college park, ga
adio
