How well will this work?
its_no_ray_ray
well i needed a new distro block so i bought this one
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=170346335545
how well do you think the voltage/amp meters will work? i dont really care that it has them it was just a plus i guess.
* BLUE DIGITAL VOLTAGE/AMP DISPLAY
* BLACK CHROME END CAPS
* ACRYLIC COVER & BASE
* BLOWN FUSE INDICATOR LEDS
* 1-0 GAUGE & 1-4 GAUGE IN
* 2-4 GAUGE & 4-4/8 GAUGE OUT
even if the voltage/amp meter doesnt work well at least i have a decent fused distro block.
what do you all think?
i just got it in the mail. it looks like it is made very well. i dont have my car right now so i cant install to see efficient it really is. even if it isnt it's still a fused distro block
looks pretty cool! but it has agu fuses? don't agu only go to like 80amps? I got a distro block from KNU it used mini anl fuse and it worked like a charm! plus it had the volt display which was dead nuts!
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-22D
but ya how does that one work? do you care for it?
it may use agu fuses. but it should all be okay since u have 4 slots for the fuses shouldnt they all be together in one
well i was thinking he was going to run 4 amps off of the distro block but ya you can add them to get a min of 90amps and max of 360amps! so depending on the application he should be good! but lets hope those fuses are hooked up in parellel that way you can add there ratings lol!!
its_no_ray_ray
its_no_ray_ray
here and there
CrazyKenKid
