The short and easy route would be to enter the box specs into an online calculator. It won't be 100% accurate but it doesn't have to be if it's just for setting the SS filter. I'd just set it to 20hz, thne work my way up if need be. If it's a sealed box then the SS filter needs to be off.this might be a stupid question but how to you find the tune in hz of the enclosure?
Depends if you buy a new one or a old school one. I got mine for $15 + shipping on ebay and it works like a charm for all my repairs I do.aren't oscilloscopes a little pricey?
How do you accurately tune the sub sonic and lpf because on my amp there is like 40hz on one side and 200 on the other with nothing in the middle, like this http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/XT_600XD_300XD_InstallSheet.pdfYou could do what 90% of the people here do and set it by ear.
Or you could read the Gain Setting Tutorial for the DMM method. Which is a sticky I might add.
The bass boost is easy, set it to 0. Subsonic is also pretty easy, just set it 5-10hz below the tune of your enclosure. If you hear the woofer making mechanical noise with low notes (below your box tune) turn it up more. LPF can be different depending on how high YOU like your sub to play, most people just set it between 70-80 hz. All this can be found numerous times via the search bar in greater detail.
Be a good guesser, lol. Just use your ears man. If you think the sub isn't playing high enough for your taste, turn it up. If you feel it's playing too high, turn it down.How do you accurately tune the sub sonic and lpf because on my amp there is like 40hz on one side and 200 on the other with nothing in the middle, like this http://www.mtx.com/caraudio/products...stallSheet.pdfhow do you know your at the number you want to be at?
also I've heard some people say tune it 5-10 hz below the tuning of your sub and some say the tuning of your box, which one is correct? for a box tuned at 35hz below would be 25-30 right, now the other way.
!!!!! thats amazing i want an oscil for this **** cheap ha sounds like quite a deal im surprised at that cheap it works. handheld? or a full osciloscope?Depends if you buy a new one or a old school one. I got mine for $15 + shipping on ebay and it works like a charm for all my repairs I do.
