How to tell if a Fi BL is fully loaded?
SSS 18734
Dollar Menu Millionaire
I found a great deal locally for a pair of 15" BL's. He claims they are fully loaded. My question is, how can I be sure of this if he doesn't have any paperwork proving them so? Are there physical differences with the subs that have cooling, flatwound coils, hyper poles, or between ones that have the "daily" and the "SPL" option?
I'm meeting with him later today, so some quick responses would be appreciated!
FW coils look different. that should be an easy one cooling, probably not. I have yet to hear of these hyperpoles? and Isnt the SPL vs Daily in the gap?
fully loaded bl weighs 1.9 pounds more than a non loaded btl. should be 43.2 pounds unloaded, if they load it up 45.1 pounds
I believe the '09's weigh ~45 pounds, correct? I'm pretty sure these are the older style, and from what I hear, they are lighter than that. Any idea on how much those are supposed to weigh?
Look through the cooling holes in the bottom part of the basket where you can see the paper part of the coil (right above the winding) and they should have written on the former what options are on it. (FW means flatwind, FC means full cooling) and it should have what coils are in it (D1 or D2).
the copper on the coil will be flat and it will have plug in the pole vent. the leads will be woven as well. i had two and one was loaded and one had some options on it and i was told it was fully loaded but they still worked together just fine
Leads won't necessarily be woven. If it's an older model like mine they are still the "free" tinsels, and not woven into the spiders..
I picked both up for $280 yesterday - perfect condition other than a tiny rip in one of the spiders. I figure that is easily fixable. They are indeed fully loaded. Thanks for the tips!
I also saw that they have "SPL" written on the paper on the voice coils. I'd assume this means they have the "SPL" option... I've read it isn't recommended for daily applications.
From what I understand this just means that the gap is tighter, resulting in a sub that won't be as good on complex notes or rapidly changing bass. I've read some posts on SSA that say the sub can actually be DAMAGED playing music - but there was nothing conclusive on that subject. I don't see how that can be possible, really, unless it's abused. I've seen people use DD 9500's or Pioneer 5000SPL's - flat out SPL subs - daily with good results.
I can live with it as long as they don't sound like absolute crap - when I heard them in the seller's car, they sounded decent - I didn't buy a pair of 15" BL's for perfectly linear response in the first place. I plan on putting these in a ~8 cu.ft box tuned to 30-32 hz.
Clean power will help prevent problems //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I will have an American Bass XD-2000 on each one //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
SSS 18734
SSS 18734
Kansas City, MO
SSS 18734
