BassAddictJ
ok....2 1501'd, 1 sub, quad 1 ohm voice coils....i wanna set it up to be the easiest to tune, th less gain matching the better...
i COULD run a 2 ohm load to each amp, or runa 4 ohm load and strapp the amps, which is what i wanna do probly
now here's my question, i know when you strap them, you run on of the + to the sub, an the - lead off the sub goes to the + lead of the other amp that had it's phase the other way....now...
..when you do this, do you still have to set both gains exact to each other or will one of the gains take over ina master slave kinda way?
also, since i bridging the amps more or less, i realize that the 4 ohm load will be choppe dinto a 2 ohm load, but i heard somewhere that with strapped amps, impedience rise is inverted....is this true?, why?
