How to rip DVD to Sansa/iPod/iPhone/PSP/Zune and other MP4 and MP3 Players
Aashka
9
USA
With the approach of Christmas, have you prepared a gift? Have you received a gift? iPod, iPhone, Sansa, PSP, Zune or others? Are you worried about watching your DVD Movies on these devices or listening your DVD music on them?
This guide shows you how to rip DVD to MP4, AVI, MP3, WMV, WMA, FLV, MKV, MPG, RM, 3GP, and other video/audio formats supported by popular mp4 and mp3 players by using Aiseesoft DVD Ripper.
Step 1: Install and run Aiseesoft DVD Ripper
Step 2: Import DVD.
Place the DVD into your DVD drive and click the “Load DVD” button to load DVD.
Tips: This DVD Ripper can load three DVD source, you can load your DVD from DVD drive, DVD folder in your PC and also IFO file.
Step 3: Video settings.
Select the output video format you want from the “Profile” drop-down list.
Tips:
1: You can also select Audio Track and Subtitle from their respectively drop-down list.
2: If you like the current image of the video you can use the “Snapshot” opinion. Just click the “Snapshot” button the image will be saved and you can click the “File” next to “Snapshot” button to open your picture. You can select the destination of the picture by clicking the “Preference” button. As default the captured image will be saved at:
C:\Documents and Settings\Administrator\My Documents\Aiseesoft Studio\Snapshot
3: If you want to merge the selected contents into one file you can check the “merge into one file” option. As default the merged file is named after the first selected file (either a title or a chapter)
4: You can click the “Settings” button to set your video parameters.
In the Video Settings, you can select Encoder, Frame Rate, Resolution and Bitrate for your movie
In the Audio Settings, you can select Encoder, Channels, Bitrate and Sample Rate for your movie.
when you choose the specific settings, the lower window will show the "help" to explain the meanings of each setting.
Step 4: Start conversion
Click the “Start” button to start your conversion and in a short while it will be finished.
Step 5: Click “Open” button to open your output destination file.
More tips:
1: Trim Movie
If you just want to convert a clip from your DVD movie, you can click the “Trim” button to open the Trim dialog, you can trim a duration of the selected title or chapter by either dragging the Start Time and End Time sliders or setting the time parameters in each corresponding field.
After you set the trimming time, the length of the captured clip will be shown in the Select Length box for your reference.
2. Movie Effect
If you want to change the original video effect, you can click the Effect icon to set the video brightness, contrast, saturation, etc. You can also set the special effect for your movie to cater to your need.
3. Video Crop
With Aiseesoft DVD Ripper you can remove the black edges around your movie video by checking the “Crop” option, so you can watch your movie on your portable players in full screen.
There are three methods available to crop your video:
Method 1: Crop by selecting a crop mode
Select a crop mode in the crop mode drop-down list and click OK to save the crop. There are three pre-set crop modes
for your choice: No Crop, Cut off top and bottom black edges, Cut off top black edge.
Method 2: Crop by adjusting the crop frame
The crop frame is the dashed line around the movie video. There are four adjustment lines on the crop frame. Each line allows you to crop the movie video from a different position.
To crop your movie video, you can just move your mouse cursor to an adjustment box and drag the crop frame.
Method 3: Crop by setting the crop values
There are four crop values on the lower left part of the crop window: Up, Down, Left and right. You can set each value to crop your movie video, and the crop frame will move accordingly.
Before you start to crop your movie video, you can select an output aspect ratio from the Zoom list. There are four choices available: Full screen, Keep original, 16:9 and 4:3. After you select an output aspect ratio and finish the crop, the result can be previewed in the Preview window of the program main interface.
Now you can enjoy your Christmas day with it!
iSkysoft Video Converter for Mac is a professional Mac Video Converter.It can convert video files from one format to another format and convert video to audio for Mac OS X users
Download here: intel version or PowerPC version
key Features:
1: Designed just for Mac OS
A professional mac video converter developed only for Mac OS (include Mac OS X, 10.5 leopard) users.
2:Convert video for most popular players
This mac video converter simple provides settings that almost few clicks to finish the whole conversion. There are several optimized profiles for iPod touch, iPod classic, iPod nano, iPhone, Apple TV, PSP, PS3, Youtube (web), Creative Zen, iRiver PMP, Archos, etc. with different quality in the video converter for Mac which can be used directly without any further settings. If you want iPod 320*240 files in normal quality, what you need to do is choosing "iPod (320*240) MPEG-4 Normal-.mp4" on the output format list.
3:Extract audio from video files or convert between audio files
Convert video to audio formats including WAV, OGG, 3GP, Mp3 and M4A.
4:Crop video
This mac video converter helps you crop video to remove black video sides.
5:Various video and audio settings
Set video output settings including resolution, frame rate, encoder, bit rate, and set audio output settings including sample rate, channel, encoder and bit rate.
6:Trim video
You can trim your video files to only convert a part of a video file with iSkysoft Video Converter for Mac.
7:Capture pictures (bmp, jpg) from video
Using this mac video converter for mac, you can capture images by clicking the snapshot button while previewing the movie.
8:Customize video effects
 Set movie video brightness, contrast, saturation, and choose to apply special video effects to your video files.
9:Merge file
 Merge all added files and output one file.
10:Easy to use
 The easiest Mac video converter to your videos to all sorts of different video formats with only a few intuitive steps. You can preview video files before conversion to adjust the output quality.
Aashka
Aashka
USA
butterfly2008
