how to make this picture bigger w/o distoring
Why don't you contact the realtor and ask them for a bigger pic? You can make it bigger but it will be distorted though I don't see what the issue would be as it is just black lines
thanks for the only response that was actually worth reading.
i just need to see the numbers below each room that says their dimmensions and i can go from there. i cant get it big enough to even get an idea of what they say.
Douchenozzle
The part of the douching apparatus that often is overlooked. It connects to the douche bag which collects the runoff. A nozzle is slightly more derogatory than the douche bag since the nozzle is the "business end" of the douche.
You can't save a file as a vector you ****ing noob hahahaahha...
You can use software to turn a raster image into vector but the technology would not work on that image.
You can not blow that image up witout it completely distorting and impossible to read the numbers. Only some of them...
You need to contact the realtor...
i'm guessing u mean blowing it up in Illustrator, since that uses vector
just because its a vector based editing software does not mean it magically creates a vector image from a raster image.
the image is raster, the image is small, there is nothing short of these two options;
A. contact origional creator of graphic and request a larger version.
B. blow up small image in any graphic design program and retrace the diagram using a higher DPI or image size. (ie: photoshop, illustrator, coreldraw and so on)
have fun.
kizzo
kizzo
All over
req
