how to make this 34htz
i'd say not worth it at all
but if you really want just take an inch or two off the port length, it just gets a little tricky trying to calculate tuning with a port that ends close to the wall like that one does (if you shorten the port a small amount). right now it's exactly one port width away from the back wall, so the air 'sees' a 90 degree turn. if you shorten it a bit, it's going to be a mix of 90 degree turn and normal end correction, so you're kinda guessing at how long the port's effective length is.
and 2Hz shouldn't really be noticeable.
mmata13
mmata13
houston,tx
xluben
