swollen_cu
Hi,
I'm trying to finish up a big 3.
I already know how to connect from alternator to battery.
The question is about GROUND.
I followed the factory ground from the chasis to the engine block.
The thing is that the engine block ground to chasis is all the way on the opposite side of where the
battery is located. The engine block ground is in top left in front of the left windshield.
And the battery is all the way on the bottom right next to the right headlight.
The question is Can I just 0 gauge ground from the engine block to the chasis and not touching the battery?
And lastly i would ground the battery to the chasis.
The thing is that ground from the engineblock to the chasis is not touching with the chasis to the battery.
It's basically two different locations.
I'd figure it would be okay since I'll be grounding engine block to chasis, it would be okay to connect
anywhere on the chasis since it's basically the whole entire car.
Can anyone tell me if it's okay to do this?
Much appreciated.
Thanks
Much appreciated.
Thanks
