How to find QTS of a subwoofer?
Magnus
U mad brah?
I'm typing in the T/S parameters for a new subwoofer on WinISD and just noticed the QTS was not included along with the Re.
Name MM1540 (4 ohm)
Diameter 15 in.
No. of Drivers 1
Fs 27
Qms 5.0
Vas 3.5 cu ft/100 L
Xmax 1
Sd 128.5 sq in/829 sq cm
Qes .56
Le 3.0 mH
Z 4 ohm
Pe 850
Can anyone figure out the QTS and Re for me?
Name MM1540 (4 ohm)
Diameter 15 in.
No. of Drivers 1
Fs 27
Qms 5.0
Vas 3.5 cu ft/100 L
Xmax 1
Qes .56
Le 3.0 mH
Z 4 ohm
Pe 850
On WINisd once you provide the Qes and Qms it will auto-fill the correct Qts for you.
It will auto-fill the Re for you, but you have to provide the Mms and BL.
On WINisd once you provide the Qes and Qms it will auto-fill the correct Qts for you.It will auto-fill the Re for you, but you have to provide the Mms and BL.
That must be why it's not working. I need the BL.
Magnus
U mad brah?
Magnus
Midwest
Magnus
