How to do a pro audio setup in car.
eli346
I would like to do a pro audio setup on my doors because i think it would be great for at bonfires and just for the loudness in general. Probably just a mid and tweet in each door for now. So this is a very budget build as these are going into my beater car. So what im not sure about is the crossover part. This is my head unit JVC EXAD KD-AVX1 DVD / CD receiver with 3" LCD screen at Crutchfield.com
So im going to need a 4 channel amp and a passive crossover for each side i believe? I see some of the big spl vehicles with tons of speakers in the doors how do they do the crossovers for those? I guess i just need someone to explain to me how it's done.
8 ohms + 8 ohms = 4ohms
get all 8 ohms speakers and tweeters
parts express has that 5k passive crossover for tweeter $5 out those on each tweeter
get a low 2 channel amp to power your tweets, wire both 8 ohm tweeters to run 4ohm
get a mid level powered amp 2 channel for your mids wire both 8 ohm speakers to run 4ohm
most 2 channel amps will run at 2 ohms, if you ever need to add more speakers just drop the ohm load to 2 and you will be alright, for example if you add 2 more 8ohm tweeters it will drop the ohm load to 2 channel.
good luck
good luck
Only thing I disagree with is that many A/B amps don't like running at 2ohm and will get hot and thermal protect. I prefer to use a 4ch bridged and run 2 8ohm mids per side.
good luck
Multiple tweeters are a bad idea...
eli346
eli346
United States
hispls
