How to Convert Video Files on Mac/Windows
bingguo9
Nowadays, people can enjoy videos in different ways, such as youtube.com and other online video websites, iPod/Zune and other portable players, and also play video on computer, and you can also make you own videos with windows movie make or iMovie for Mac users. So how to convert videos between different video formats is a big problem for both windows and Mac users. Today I will share you guys two powerful video converter for Mac and Windows users.
For Mac users, this powerful video converter for mac is really nice.
Let's use it to convert a video for Example
Step 1: Add File
Click “Add File” button to load the video you want to converter
Step 2: Choose profile and adjust settings
You can find your output video format from a drop-list called “Profile”
You can also adjust the specific settings of the output video, such as “Resolution”, “Bitrate”, “Encoder” and so on.
Step 3: Edit Video
1. Effect:
You can adjust the “Brightness”, “Contrast”, “Saturation” and “Volume”
2. Trim:
You are allowed to pick up any part of the video to convert.
3. Crop:
To remove the black edges and choose a play area to convert.
Step 4: Start Conversion
Click “Start” button to begin your conversion and you will get your video soon.
For Windows users, you need Total Video Converter.
Step 1: Load Video
You can load your videos into the converter by clicking “Add File”
Step 2: Choose output info
This converter provides you many output profiles for you to choose, you can choose your output profiles according to your need. And also you can just choose a certain video format.
You can also adjust the settings of your output profiles. You can even save a certain settings as your own output settings.
Step 3: Conversion
Click “Start” button to begin your conversion and few mins later you can get your video.
Tips: How to effect, trim and crop the video to improve your output video quality.
After your Load your video you can click “Effect” button to access the effect panel
1: Effect
Adjust the video effect as you want: Brightness, Contrast, Saturation and Deinterlacing.
2: Trim
Clip your video, pick up any part of your video to convert.
You have 3 ways to do trim:
1.Dragging the slider
2.Controlling the “Trim From” and “Trim To” button
3.Setting the Start and End time
3: Crop
Adjust video size, Cut off the black edge of your video to let you enjoy your movie in full screen by click the 'Crop' button
You have 2 ways to do crop:
1.Move your mouse cursor onto one of the eight small adjustment boxes on the cropping frame and drag the crop frame to crop the video such as cutting off top and bottom black bar. The cropped result will be shown on the Output Preview at the same time
2.Type the value directly or set the value in "Left", "Right" and "Cropped area size" area to set the position of the cropping frame.
You can also select the aspect ratio from the Zoom Mode drop-down list. There are 4 choices for you: Full Screen, 16:9, 4:3 and Keep Original.
How to convert your video files to portable devides?
The best video converter mac will solve all the problem for u.
To convert video for Mac, this video converter mac is your best choice which is specially designed for all Mac users to convert video formats to common formats like avi, wmv, vob, mp4, rm, dvd, mpg, mpeg, etc. Besides, it supports many popular devices as iPod, iphone, psp, zune, iTunes, QuickTime, etc.
What's more, this video converter for macstill can be used as a fantastic Audio Converter for Mac. If you are interested in this function, you can go to the Audio Converter for Mac to get more information.
This professional video converter macsupports strong edit function, which can help you to change the video and audio settings, if it is indeed. With this function, you can reset the brightness, contrast, saturation of the image quality, the length of video time, the size of video, etc. Snapshot is also supported. To save time, you can convert video on Mac by batch conversion; what is more, you can merge different files into one.
Guide on how to use this wonderful video converter mac:
1. Free download this video mac converter, install and run it, you will see a friendly interface.
2. Add your video files by clicking "add file" button, here we support batch conversion, you can merge different files into a single one by ticking before "merge into one file".
3. Select a path as an output folder to save your converted files.
4. To edit your video files by clicking the "effect" button, three choices are supported--effct, trim and crop.
5. Press "start" button to start conversion. It will be finished in a few seconds.
Video Converter Mac:Free download is supported now, please have a try now!!!
bingguo9
bingguo9
china
caribbean
