How to convert Mod video to MP4/AVI/WMV/FLV/3GP…
shareware123
NW
MOD and TOD extension is the video format generated by most popular digital camcorders such as Panasonic SV AV100, Canon MOD Camcorders, JVC (MOD and TOD) and Panasonic (MOD only). It is not the common format, so it can not be accepted by popular portable players.
Tipard Mod Converter has the professional function to convert Mod and Tod video to MP4, AVI, WMV, FLV, 3GP, MPG…. With this best Mod Converter, you can share your DIY video with your friends and view it on your portable players.
The following is the specific guide to show you how to use it:
Preparation: Free download and install Tipard Mod Converter. After you download it, double click the file and follow the set-up instruction to install it.
Step 1: Run this DVD to iPhone Converter and load your Mod files.
Step 2: Set up the output profile and the output file path.
Tipard Mod Converter can convert your Mod file into these formats:
This converter provides more video and audio parameters for you to get the perfect video quality for your player. Click “Settings” button to set it.
Click “Browse” to choose the path for you to save the converted file.
Step 3: Start conversion
After you set all the settings, you can click “Start” to start conversion.
Tips:
1: How to join your file pieces
If you want to merge several files into one file you can choose them and click the "Merge into one file" to do it.
2: How to split your video
The "Trim" function also servers as a video splitter for you to get any time-length video episode. You can set the "Start Time" and "End Time" to set the time of the clip or you can directly drag the slide bar to the accurate position.
3: How to crop off the black edges and adjust the size of video play region
By using the "Crop" function you can crop the black edge of your video and you can also drag the line around the video image to adjust the video play region to fit for your mobile devices.
4: How to save your favorite picture
If you like the current image when preview video, you can use the "Snapshot" option. Just click the "Snapshot" button the image will be saved and you can click the "Open" button next to "Snapshot" button to open your picture.
Appendix: Tipard Mod Converter Mate is the perfect combination of DVD rip software and Mod Converter. With the only one tool, you can both convert DVD and Mod/Tod video to the video and audio formats for your portable players..
shareware123
shareware123
NW
shareware123
