How to convert Mod/Tod Video to popular video formats
garytebow
question:
1: What is .Mod and .Tod video?
2: How to convert .Mod and .Tod video to AVI, MPG, WMV, MPEG?
Answer:
1 .MOD and .TOD is the video format generated by most popular digital camcorders such as Panasonic SV AV100, Canon MOD Camcorders, JVC (MOD and TOD) and Panasonic (MOD only). It is not the common format, so it can not be accepted by popular portable players.
2. Now with this professional Tipard Mod Converter, you can easily convert your Mod/Tod video to any video format supported by your portable device.
The following will show you how to convert .Mod and .Tod video
Step 0: Download and install Tipard Mod Converter
Step 1: Click “Add File” button to add your video files.
Or you can click “File” button to open the following drop-down menu, then select “Add File”to import video file.
Step 2: Select the output video format you want from the “Profile” drop-down list.
You can click the “Settings” button to set parameters of your output video such as Frame Rate, Bitrate to get the best video quality as you want.
Step 3:Click “Start” button to start your conversion.
The conversion speed is very fast, just in a short while you conversion will be finished.
More editing functions
1. Video Cutter
If you just want convert a clip of your video, then you can use the "Trim" icon to set the Start time and End time of the clip or you can directly drag the slide bar to the accurate position.
2. Video Crop
By using the “Crop” function you can crop the black edge of your video and you can also drag the line around the video image to adjust your video to portable devices..
3. Video Joiner
If you just want converter a clip of your video, then you can use the "Trim" icon to set the Start time and End time of the clip or you can directly drag the slide bar to the accurate position.
4. Snapshot
If you like the current image of the video you can use the “Snapshot” option. Just click the “Snapshot” button the image will be saved and then click the “Open” button next to “Snapshot” button to open your picture.
Ok, with this powerful and easy-to-use program, convert and enjoy your .Mod and .Tod Video is so easy, have a try now!
Tipard iPod to PC Transfer
Mac Video Converter
garytebow
garytebow
shenzen
garytebow
