How to Check Blown Fuses
it is possible for a blown fuse to be overlooked, but to be sure it's not blown it's allways easiest to put a new fuse in and see if it works, or if you want to get fancy you can use a multi meter and ohm out the fuse from one side to the other which will tell you if the fuse is blown or not.
agu fuses are notorious for blowing not in the center but at the end, those can be tricky soemtimes to see.
but the easiest way to find out is just put in a new fuse
With a multimeter set for DC volts or a test light, attach the black lead to ground then probe each end of the fuse with the red lead. If you have voltage on one side but not the other, you have a blown fuse.
Standard automotive "spade" fuses have two access points at the top of the fuse, so they can be tested while they're still seated in the fuse holder. Depending on the fuse location, you may need to turn the vehicle's key switch on to get power to the circuit before testing.
This method is both much easier and more reliable than continuity testing.
Jake95
Jake95
Evanston/ Chicago, IL
KaeZoo
