How strong is Wood Glue?
Well, honestly this was posted in the wrong section 'cause I didn't really know which section to put it in. But I'm building a TV-Stand type of thing and I don't know what to use for the bracing.
ref image [same bracing on the right as on the left]
How much a single joint can hold is not only dependent on the wood glue used but also on the wood used and the surface area that you're applying it to.
If you're planning on using MDF, that structure will probably not support too much weight and will probably flex over time. MDF isn't really a load bearing wood.
If you're not putting anything heavy on top, you will probably be fine though. I would worry much more about the wood than the joints. If you're not using MDF and some kind of hardwood, you should be in better shape. Maybe beef up the rear 90* support though; I would probably double its thickness to keep it strong.
Yeah, I know what you mean. I'm not sure which wood to use. I was thinking MDF, but then I realized that all the heat/weight would ROCK it.
The top shelf will hold an Xbox, controllers, maybe a few games... and, knowing me, cups. It's not back-breaking weight... only about ~25 lbs at most. But the wood itself will be pretty heavy. I might double-up the strips. It's all based around getting 1 or 2 sheets of 3/4" wood. I could upgrade to 1" if necessary. But, I didn't want a like 3" x 2" beam going up since I don't know how to do that. But, I guess I can double up the strips and make 2 strips of 1" thick, then glue them together and have a 1"x1-1/2", or maybe boost it to 2"x1-1/2[or 2-1/4" with three strips]
What I never thought of was bracing for the shelf that will hold my TV. It's a 27" Tube TV [sDTV lolz... but it's pretty badass. A really good TV for the like $70 bucks I paid for it], so it's pretty bulky and heavy. I'm not sure how heavy exactly.
Do you suggest a type of wood? I've heard Birch wood was badass... but I'm not sure about it's integrity.
EDIT: 350 post //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I would get tightbond though. As that seems to be stronger. Both did the same thing. But still I like to work with tight bond more.
Any online store I have to get it from? Or do you think they'll sell it at like Ace or Home Depot?
IDSkoT
Resonating Reticular
IDSkoT
Miami, Florida
Heavy Hitta
