How much power will I need for RF T40001bd
bumpin buick
Science is everything
I have a RF T40001BD and plan on running it at 1ohm in my 2000 Toyota 4runner I have contacted a few companies about HO alternators and I need to know what you guys think will work the best. Also how many batteries will I need to run it without voltage problems. Im looking at either the Powermaster 3100 or Kinetik HC2400, how many should I purchase?
Heres my options so far on HO alts:
Boss Load
170amp- $220
Excessive Amperage
200amp- $265
250amp- $290 (needs a modified bracket)
Powermaster
still waiting
Iraggi
200amp- $419
Think even with that I would have problems?
i really doubt it..... but you never know. You might be able to get away with 1 batt, then just order another one if you need it.
I run a voltage meter off my amps input ever since I saw a 1000+$ amp go up in smoke due to a loose ring terminal at a battery in the back.
also can you guys check over this, does it look right. I feel like im doing something wrong but just not sure.
bumpin buick
bumpin buick
Appleton, Wisconsin
jerryrobinson
