how much power rms can 2 sa12 take
can 2 sa12 handle a zx2500.1 @ 2ohms 2834 rms @14.4 I can hold 13.8 with new electrical upgrades . or will 12**rms at 4ohms be better, but wouldn't be using amp to full capability. thanks for any info and suggestions.
I would run two ohm but set the gain to around 1600. That would make a very clean signal with a lot of head room.
i was running my SA-12's at 1k each off of a SAZ-2000d. took it fine. but i wouldn't run anymore than that to them... so i'd say 1k each is what they can handle as long as you know what you're doing and set everything right
Oh that was just a temporary setup. Had it wired at 1 ohm plus impedance rise. I never clamped it either so not sure how much I was throwing at them but even at that, they did take much more than rated like a champ for 2 weeks. I definitely loved those subs. lol
i saw your video, man was that poor civic taking a beating.
You can run the rated 600 watts or double it and run 1200 watts, it isn't going to be twice as loud maybe about only 3db louder at twice the power, unless you are competing it is going to be that noticeable. (output does not increase in a linear fashion as amplifier power is increased).
How many more db would i need to be twice as loud?
kirby mane
kirby mane
Tuscaloosa,Al
Buck
