how much power do I need?
Kicker 2500.1 2.7-2.9Krms on average birthsheet.
your mmats does not get them loud? are they wired at the right impedance 200DHC isnt there a number after the amp model that indicates where it makes the most rms?
I recently hooked my 2 15 Memphis mojos up to a mmats d200hc and I was shocked. I was wondering how could I maybe max out or come close? I was thinking a hifonics Zeus(2500w@1ohm) the speakers are 1000\2000w peak
You were shocked.... how wet the vibrations made your mom? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
ok I wasn't specific. With the 1200 watt mmats the entire car shakes. The rear veiw won't stay focused and I can't hear what the passenger is saying... I love it! I want more power out of the speakers. I wired it with 4 gu wire to the cars battery. If I get more power I probably will get it professionally installed by a local shop.
why? it already has the wires run. why pay to have some one plug in an amp? or run a 1/0 guage wire where you already know how?
it sounds like you have not done any electrical work on the car if your still using 4g. look up how to do the big 3 and look into an alternator. if you just keep drawing as much power as possible you will fry your stock alt because itll be running at full tilt all the time.
If that amp is doing your subs justice, something is wrong.
I have personally had that amp and I kick my own arse till this day because I sold it. This is assuming it is the older MMats amp.
Buddy has the same amp you have and it kicks the shit out his Envoy. Very loud to say the least.
Actually I dont. I was at a friends garage and did what I saw someone else do. It kinna looks sloppy and unprofessional.
I didnt know that. That's y I wanted to get it done professionally. I just threw it together. I'm sure the shop could help with that.
well seeing how I'm looking for somethin stronger it will be for sale... Any interest? Btw I have a 97 grand marquis and i put my bookbag on my trunk while full of books(25lbs) and it bounced it close to a inch in the air
i dont have experience with those subs, but u will pry be close to pushin them to there limits.
i would pry get a new amp and new subs. Get the kicker 2500.1 and some high end re's, fi's, mmatts, soundstream, and anything else comparable to those high end subs.
u will also need to upgrade ur wirin throughtout the car, do the big 3 and a couple of batts. And if u still have voltage problems, whcih u pry will, u will need to upgrade ur alt
look into the classified here, there are some crazy deals.
e126824
RIP chevy caprice.....
e126824
detroit mi
nauc
