How much power can SE's take on a daily?
depends on the install, most the time I wouldnt image you need 1000 watts each to get em going.... never had a chance to play with one though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. GB price is tempting lol
i powered my ten with a good 700watts, and it did quite well. but then again, its ALL in the install. you could probably get away with 800-900, but i wouldnt go too much over. a 1000each is a little much, unless you build the right box. but like bimma said, the truth is, you dont NEED 1000watts to see there full potential, mine did fine with 700, and i deffinetly expireienced the full effect of it, very nice sub.
RMS on the SE-12 I have in the Honda is 600W. For that reason I put the KX600.1 in my sig to it and it does pretty well. When the GB rolls around I will be picking up 2-10's or 12's for my truck install to finish it up. Want to start searching out an amp to power both. I thought maybe I could give them something with a little more room to grow. How accurate are the birth sheets that come with the Kicker amps? My 600 has a birth sheet rating of 755. Safe to say I have about the max going to the 12 in my Honda?
my 1200s say 1350 and 1400... somewhere around those numbers... pretty much around the area I have seen on most sheets. Look for something thats 1200-1500 watts at 1 or 4 ohms. Tons of choices in many prices ranges as well //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I was thinking about another Kicker amp. Maybe a 1200.1? Don't see any talk here about Kicker amps so I wonder if they are just as good as the next or am I the only freak using three and looking for a fourth?
I know someone who ran a 15SE ported off an RE 35.1 @2ohms. That's around 1100watts, and it took it all day everyday for months. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
NG
NG
i ran my rl-p on one for a couple weeks and i got my av12 in there now on it @1ohm
How do you like that SE12 in a 1cu ft sealed? Thats the setup im looking at now. One SE12 in 1cuft sealed with a 600w rms alpine pushing it.
Intercooler
Intercooler
Maryland
eisenhower
