how much power can i get?
I would say a 1250 would be good, 1500 max but i would not go there.
I ran 1100 on my 110amp alt for a while with very very minimal dimming.
I should be able to run 2000 wrms easy. Im running 1500 on an 100 amp alternator and a Kinetik HC800 in the back with no big 3 at all. I have no dimming, even when Im on max. BTW duralast red top up front:D
its very vehicle dependant. I am running 1800 off of a 90 amp alt, deka intimidator 9a31, and no big 3 (yet) and my voltage stays in the high 12s-13. voltage only drops to 12.5-.6 burping 2200watts with the car at idle
What is your goal. I say keep the alt, do the big 3 and add a battery in the back and that should do it. I always say the alt should be your last option.
jump up from 1000 watts to maybe 1500 watts. just seeing if it would give my electrical any problems
1.5 db's will be almost not noticeable......... it take about 3 dbs for a human ear to notice a difference, everybody's hearing is different however.
double power = 3db (in your case 2000rms)
double cone area = 3db
05fronty
SALT PETER
05fronty
conway,ar
UNDERGROUND_BUM
