How much port area?
I already have the plan that I have done up. It is kind of coplicated I just want to make sure that I am not going to have port noise. The port area I have is 50 sq inches just want make sure this is enough.
As long as you have about 20 inches per sub you will be fine. I always like to keep a ratio of about 6 to 1 on the slot ports....in other words if the port is 6 inches high then it should be 1 inch wide and 12 inches high and 2 wide etc. You don't want a port that is 50 inches in length and one inch in width. The smaller this ratio the less chance of port noise.
air speed in port shouldn't exceed 17m/sec which is speed of sound.over this it will be audible.
larger ports lower the speed but need more airspace.
you can checkout with winisd.
trigger2008
trigger2008
Mechanicsburg,OH
luv2bass
