How much fiberglass and resin
ashren315
I'm about to order my fiberglass and resin from UScomposites and I was thinking that 2 gallons resin and 10 yards by 38" 1.5oz fiberglass matt should be enough to do my two kickpanel enclosures and a 1.4 ft^3 spare tire well enclosure. The top of the enclosure will be MDF so only the shell inside the spare tire well will be fiberglass and will house one 12" sub with about 300 watts going to it. Was going to do 5 or 6 layers.
Does this sound like enough fiberglass and resin for this project?
Sounds as good a guess as any. You really won't know until you start laying it up how many layers it'll take to make your spare tire well feel solid. I did that ages ago and I do recall it took a bit more than I planned, but then again it was the spare tire well in a 1980 Lincoln Town Car which is pretty big.
common sense stuff get more than you need, suggestion rating 0.0
I've found IN MY EXPERIENCE that common sense is not nearly as common as it's purported to be, often! I said I wished I'd gotten more Damplifier Pro. Luckily I'd bought some BQuiet. Not nearly as good as Damplifier Pro but certainly better than nothing.
John Kuthe...
John Kuthe...
I can completely understand that common sense is not common in your experience.
ashren315
ashren315
Canton, MS
JohnKuthe
