how loud will 4000 watts be
Lol, this thread=fail.
But if I recall what a "professional audio salesman" told me (this is a true story)
When you plug a subwoofer into a 120 volt wall outlet it will play them at 120 decibels, and it's not the power that kills them it's the frequency because almost no subwoofers can stand a 60 Hz signal. So 4000 watts at 1 ohm would mean 63.2 volts=63.2 decibels. Sorry man //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
wow, do you actually beleive what you just typed?? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif if so you should go back to school. 120V house current is AC current, which is what speakers run off of. 60 HZ is actually perfectly do-able for most speakers larger than 6 inches(and some that are 6 inches, just depends on the design) 120V does not = 120DB... your house wiring can basicly put out however many amps you need as long as the breaker doesnt trip or the wires dont fry. so lets do some simple math:
120V X 10A = 1200watts (V stands for volts and A stands for amps, u follow??)
120V X 40A = 4800watts
so lets say your "plug a speaker into a wall outlet" scenario with a 40A breaker would give at least 4000W. that sub would play a consistant 60HZ tone(actually its more like 57-63HZ, it varies a bit).
the output in DB would depend on the actual sub used. id go into calculations on how to figure out an aproximate DB reading but i dont think you havemuch higher than a middle school education.
/rant
Matt
oh and power doesnt kill subs, HEAT AND/OR DISTORTION do.
and one more thing, i have no clue how u came up with the 4000W at 1 ohm = 63.2 V. i guess i must have slept through that part of engineering. enlighten me if you dont mind.
/rant
Matt
dude calm down he was just kidding LOOL!!
I'm not kidding that the guy said that, that part is true. That's why I put "professional audio salesman" in quotes. Thought that was obvious.
Anyway, tell me, how do you set the gains on your amp? Use a multimeter. Turn your stereo to about 3/4 power. If you have an 800 watt amp at 2 ohms calculate it as volts squared divided by resistance=8000. So volts*volts/2=800. volts*volts=1600. square root of 1600=40, so 40 volts at 2 ohms will put out 800 watts.
Now, to figure out what 4000 watts is. 4000=volts*volts/resistance. If the resistance is 1 ohm, 4000=volts*volts/1. 4000=volts*volts. Volts=square root of 4000=63.2 volts.
Seriously: I've used "LOL" a million times in my lfetime, but I have never actually laughed out ****ing loud until now lmao
I'm still not even sure if this thread is serious or not??? I just don't know lol
lol, i missed the quotes. my bad man. thanks for explaining the whole volts / ohms thing, never knew how to do that.
sorry but i get pissed when pple post stupid shit. im a noob, and ill admit it. but i know alo about what should happen or should be happening. i have heard alot of diferent sterios and that is what i make my comments from, personal experiance.
oh and i dont set my gains, i let professionals do it. havent had the guts to set shit up myself thus far, dont want to blow anything. but my next settup i will tune myself.
Matt
i got a boss 4000 watt amp and im wondering how loud it would be:confused: i want them to be able to hear me before they see me.
i saw the title, and had an "lol" moment
came in, saw this and almost died //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
i'm gonna go with "what is, amps don't get loud, Alex"
99grandprixGT
now got an 04 grand prix
99grandprixGT
home
Lakota
