how do you test an amp to tell if it is bad
it is grounded and the remote wire is hooked up although the remote wire may be messed up it was missing from the harness and i had to replace it with a different wire. i think that is probably the problem. can you run the amp without this wire?
jump it with a little piece of speaker wire from the +12 input on the amp
well i jumped the remote wire and the power wire and the amp turned on so it must be the remote wire not hooked up properly. thanks for the suggestion
KAMAKA Z
KAMAKA Z
omaha ne.
KAMAKA Z
