wow i really didn't expect to get this many quality responses to my question. thanks all.
Try switching the polarity of one of the tweeters? Idk, just a shot in the dark.Do the tweets sound bad to you? If it sounds good, who cares if theres some cancellation displayed on a graph.
wouldn't this cause more issues that just the original 3k-3.2k? meaning those may be more in phase, but wouldn't the other frequencies that were previously in phase now be out?
and yes, it sounds great to me, but i'm always on a quest for better. i'm sure anyone who's on this site can appreciate that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Are you running your mids/tweets passive or active. If it's passive more then likely it's from/caused by the xover.
active
After reading a bunch of back issues of car audio mags there was an article about this, and the question was posed, Why would you want a flat EQ? As it doesn't sound good to 99% of the people out there, myself included. Play some albums you're very familiar with and listen to them in the car. How does it sound to YOU?
JUST BECAUSE THERE'S A DIP HERE/THERE DOESN'T MEAN IT WILL SOUND BAD!
Everyone hears the same, what we perceive is the difference, our tastes or styles is where the difference will come from.
i'm using the system to start with a completely flat and in phase base, then i'll tune to my liking from there. i'm mostly using this to "train" my ear as to what a perfectly time aligned and flat eq should sound like, and running into issues along the way. sorry i forgot to include that in the original post.
To try and fix your phasing issue, try and run the mids reversed and the tweeters normally. I'm assuming you've played with the polarity on the tweeters already and may or may not have tried it with the mids.
i really haven't played with the actual polarity much of the tweeters, i assumed if i was only having issues with a specific set frequency and not all frequencies that flipping one would have an adverse effect. maybe i'm thinking about this all wrong, and, if so, would love for someone to explain this to me.
I am assuming your crossover freq between mids and tweets is around 3k, the very nature of a crossover will cause phase issues - not much you can do about this. If you move the EQ 3 or 4 notches and the amplitude doesn't change then don't worry about it.
yes this is what it was in the passives, so it's what i started around. however, even with moving the xover above and below the problem frequencies, i still get the same issue, which is why i was thinking i would need something external to tune.
I'm more of a home audio guy, but I can vouch that flat or close to flat can/does sound really good at decent volume levels.....to a huge amount of people. At lower levels, it may not sound as good because Fletcher-Munson kicks in. That's where custom EQ or "LOUD" EQ curve adjustments can come in handy.
funny you should say that (the Fletcher-Munson theory). this is actually the reason why i hooked up my car to the system in the first place.
