how do u pimp out a caravan?!
dont know what exactly u mean
when you chop a top, you cut some out of it, and then weld it back together(simple answer)...bringing the top of the car closer to the body, it makes them look better, IMO...but there is alot of work involved...especially on a van
If you wanna get a van, get an Astro or something like that.
I assumed he was talking about his current van, the one in his signature.
The reason I say it isn't worth "pimping out" a Caravan is simply because you need to spend quite a lot (unless you do your own body work) to make it look halfway decent. Good paint work, classy but not tacky or gaudy wheels, and engine work doesn't come cheap. If you can spend all that, you might as well buy a stripped-out cargo E-150 or Astro and build a proper van.
Paint it black wit black outs on the front and back wit a custom grille, all tinted wit sum nice 18's, u need an in dash screen and a 10" inch falling for the rear passengers. If not black paint, make it white wit everything else said then you will be pimpin, dont forget the fuzzy dice hangin from your rear view mirror
They aren't there now, however...
Did you take off the stock emblems, that would be the next thing, then add like the DUB decals or whatever you like, they also have the the numbers which signify the size of your rims decal, just a thought though. Also you can put Chrome caravan decals in a nice font, check your local pinstriping company they will give you good ideas
chitowns finest
Raw power and ignorince,
chitowns finest
chicago
AcidicDreams
