How do i do this?
iirc, to get into the dash of those mustangs, you pull the panel that's under the shifter. That will expose 2 screws at the bottom of the dash panel. Then, after you unscrew those, pull the panel off.
To pull the door panels off, just unscrew all the exposed screws and use a panel popper to pop the clips.
if you have manual windows there should be one under the handle
yeah, and don't forget the oh-shit clip. If you've never done one of those before, depending on how much flex your door panel has to it, you may need needle-nose pliers, a 90* pick, or even one of the clip-removal tools.
TWF
TWF
enterprise, ms
jmanpc
Mike Mccabe
