King_Of_Da_Souf
~Playa 4 Life~
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I have decided to use rockford's recommended ported enclosure for my Power HX2 15". The recommended enclosure calls for 4 (4 X 18") round ports. The problem with that is that the box is only 18" in diameter. So, i have decided to go with a slot port that will help with bracing anyways.
I believe that it is tuned to 33hz
The dimensions of the box are: H-20" W-25" D-18"
Box volume: 3.5ft^3 (net)
if i want to use this box, but with a slot port, how could i convert the info i have to get the info that i want (port specs. of a slot port so that i can build me a box)
P.S. this is my first box
and i do understand that the box dimensions will probably change, this is acceptable
