bdonkersgoed
Hey Guys,
My Equipment:
- Alpine CDA-9835HU
- Focal Utopia 165W 2-Way Components in Front
- PPI Ax400 to power Utopias
- RE-XXX 6.5" Midbasses for rear doors
- Orion HCCA 225G4 to power XXXs
The Problem:
Now, my problem is this . . . how should I connect the RE-XXXs to the Orion HCCA 225G4? It is a cheater amp, so it likes to see a low impedance. The mids are 1.75ohms, so if I connect in stereo, the amp will only produce about 65W RMS, but the XXXs want to see 150W RMS. Is there a way to wire up the RE-XXXs in mono so that I get a larger output from the Orion, more suitable to the XXXs? The RE-XXXs are going to be the bass line of my car, because I will not be having any subs this time around. See the specs on the Orion and XXX below.
Here are the specs on the RE-XXX 6.5" Mids:
RE: 1.75 Ohms
Fs: 47.4 Hz
Qms: 2.33
Qes: 0.59
Qts: 0.473
Mms: 15.04 g
Cms: 7.505E-04
Vas: 21.49 ltr
1- way Xmax: 13mm linear
Le: 0.14mH
Bl: 3.636 t/m
Power: 150wrms
Spl: 87.75 dB 1W/1m
Here are the specs on the Orion HCCA 225G4:
4.0ohm stereo ~ 25W RMS
2.0ohm stereo ~ 50W RMS
1.0ohm stereo ~ 100W RMS
0.5ohm stereo ~ 200W RMS
4.0ohm mono ~ 100W RMS
2.0ohm mono ~ 200W RMS
1.0ohm mono ~ 400W RMS
Please help ASAP.
Thanks!
Bryan
My Equipment:
- Alpine CDA-9835HU
The Problem:
RE: 1.75 Ohms
Fs: 47.4 Hz
Qms: 2.33
Qes: 0.59
Qts: 0.473
Mms: 15.04 g
Cms: 7.505E-04
Vas: 21.49 ltr
Le: 0.14mH
Bl: 3.636 t/m
Power: 150wrms
Spl: 87.75 dB 1W/1m
Please help ASAP.
Thanks!
Bryan
