How can you tell how clean an amp is?
look at thd and signal to noise ratio
on thd,the lower the better
on signal to noise ratio,the higher the better
plus you get what you pay for,meaning,dont expect great things out of a $50 1000 watt amp,versus a $1000 50 watt amp.
look for good brand names,jl,alpine us amps etc...versus boss,pyramid,legact.
That's my question. Is there something in an amps ratings that tell you how clean the amp is? If not than how can I tell if this amp will give me cleaner power than that amp?
Thankx.
Aside from the normal parameters you see published, I would look at
lower impedance power ratings. Manufacturers won't publish bad
distortion numbers in spite that it might have it, lol ...
Because speakers are reactive, the amplifier needs to handle this
issue to ensure it performs well. With the exception of power regulating
amplifiers {very few on the market, I can only think of one}, if the
amplifier has higher power ratings into a lower impedance, that is good
news. ie
Roughly..........
Great specs;
100w/ch @ 4 ohms
200w/ch @ 2 ohms
400w/ch @ 1 ohms
Very good specs;
100w/ch @ 4 ohms
175w/ch @ 2 ohms
250w/ch @ 1 ohms
Good specs;
100w/ch @ 4 ohms
150w/ch @ 2 ohms
200w/ch @ 1 ohms
Weak specs;
100w/ch @ 4 ohms
not 2 ohm stable.
The weak amp would probably be good only to drive easy loads like tweeters.
I mean of course its nice to see an amp create more power into lower resistances, I don't think thats an ideal way of determining if the amp is clean or not.
There is no ideal way by just looking at specs. But if you are limited to looking
at specs, I always check it's power capabilities also at low impedance, it's
another variable to learn how the amplifier hehaves. If it can't drive low impedances well, SQ can suffer.
also, not that this is a way to judge, but most companies that overrate their amps aren't the best. and switching that, companies that underrate thier amps usually have higher quality standards.
I'm surprised this thread has made it this far w/o starting up the "amps don't have sq" debate.
In my simplistic view - it's like this.
A high quality amp (say -- RF and beyond) will be "clean" at rated power and any stable impedance. "Clean" at least to a level far beyond what we can distinguish.
A mid quality amp (ex Hifonics) is going to be clean until it gets near rated power - where it may begin to clip and sound not so clean.
A low quality amp (ex pyramid) is going to sound clean at low power and distort long before you would expect it to relative to the ridiculous power ratings.
AMA
AMA
TX
AMA
