How can I tell if a Treo subwoofer is an SSi or SSX
Get a digital multi meter and check the coils to see if they are 2 or 4ohm
And look for pictures of the motor (magnet stack and the rest of the goodies on the rear) for each sub
And they might have different baskets..... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Throw up a pic and I will tell you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Polo..//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
SSIs have a chrome magnet with no markings on them, SSXs have black rubber around the mag and actually say SSX on the bottom unless the sticker has been removed. The hole in the mag on SSis are about 2.5 in across since it has a 3" coil, SSXs hole is about 3.5" wide since it has a 4" coil. Use a dmm to test the ohms, but all SSxs are D2 unless special orders
one weighs about 20 pounds, the other about 60 pounds. hope you feel the weight difference. the ssx motor is about twice the size of the ssi
heres my ssx 18
can't find pics of my ssx 15 i had
btw if you can't tell the difference easily between an ssx and an ssi, then you shouldn't be driving a car or operating machinery lol
heres my ssx 18
Hey do you still have that sub, or did you sell it?
Dual SSI 10.22 on a strapped pair of Kicker SX1250.1 's @ 1 ohm
It was hot on both of those days and with a black car the subs started out hot (heat saturation) so I purposely turned the gains down to stop the magical smoke.
Polo..
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
338
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Without a photo this is the best I could come up with, note the "physical port length" is at 22.5" and if you measured down the portwall to get...
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
jondoe82
jondoe82
Ocala, FLorida
Safe_Cracker
    May 12, 2024
Brendon Jenness
    May 11, 2024
