I got this indash dvd Hu from a friend and not sure if it still works? I dont want to splice and install it in my car to figure out if it works or not. I was wondering if theres anyway we can check it with a voltmeter.
Yes, you would need the remote wire or ignition wire connected also.connect (usually) the red and yellow to power, and black to ground. if its working it will turn on.
either red or yellow is power/accessory (not sure since i think its switched around on my eclipse). but connecting both to the battery pos. solves the problem of not knowing
thanks man, its getting dark , and im too lazy to take the dash apart to test this HU out. So if i were to test it straight from the battery i still need to connect the ignition key?innsanes i still cant get over how sick those things are in your avatar!
