How can i acheive a HAIRTRICK?
Are you set on running 4 12s?
If space is a deterrent then makes sense, but if not, why not come out cheaper in the end with 2 18s? and being louder
how my amp rack and battery rack is set up that's the most I prob fit. I may be able to run two 18s but the subs would be .5inch apart
Setup properly should be no prob. 4 12"s will have to work pretty hard to do a good one but 4k should get it goin , if you are so worried about the hair trick go with bigger subs.?. if ya got the room
southport2014
southport2014
Indianapolis, IN
murph
