How big of power wire can I hook up too this amp?
Really hm ok I wanted to hook up o gauge wire but o well. If hey have both 100 and 150 amp fuse what one do I get does it matter?
I'd go with the 150.
And you can hook up 0 gauge, but you'll need to either trim the end down to fit in the 4 gauge slot, or use a 0 to 4 gauge reducer. Also if using 0 gauge, you'll need a 300A fuse.
Ah, why would he need a 300amp fuse, just because he runs 0g?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Ah, why would he need a 300amp fuse, just because he runs 0g?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
You should always fuse for the wire size, not the equipment. At least that's how I was taught and have always done it, and still do.
nope... they are great amps. Its just as easy to run a 1/0 run of power wire as it is 4 gauge so you might as well do it right the first time. THis way if you want to amp your mids and highs you can just feed off of a distribution block.
So if I do run o gauge wire I would need gauge reducer right? What fuse would I run if I run o gauge?
Did you just quote yourself? lol
A simple distroblock would suffice and you can get them from many places. There might even be a few for sale here on the site. If not check ebay, Knu, etc.
hitman34608
hitman34608
Knoxville,TN
hitman34608
