Hooking up a DVC sub...
jgarcia9102
ok, now this may be a stupid question, but its never really been explained to me.
If i have a 4 + 4 DVC sub, and a 2 channel amp, what are my options for hooking it up?
I have read that hooking up a voice coil to each channel will blow the sub, and i dont doubt it, but then what does that leave me?
The only thing i can think of is running the sub at 8 ohms and bridging the 2 channels to see 4. (because the amp isnt 1 ohm stable)
4ohms from a bridged amp just seems like a waste to me though. is there any way around this?
you can hook up the sub to a two channel amp. i did it for a few years. didnt damage my sub at all. bridge your amp and run your voicing coils in parallel your load on your amp will only be at 2 ohm
but how do i get a 2 ohm load? i dont see how thats possible with a 4 + 4 DVC.
i can wire the sub to be 8 ohms or 2 ohms. if i bridge it at 8 ohms, the amp sees 4, if i bridge it at 2 ohms the amp sees 1.
the only way for te amp to see 2 ohms is if i run each VC to a different channel, which i was told will kill your sub...
a DVC 4 ohm sub can be wired to run at either 2 ohms or 8 ohms. If you have a 2 channel amp wire one coil to each channel so each channel will see 4 ohms. If you bridge the amp.. you will most likely have to run the sub at 8 ohms.
Since you havn't bought the sub amp yet, why not just get the CORRECT one?
jgarcia9102
jgarcia9102
Rochester NY
johnecon2001
