ckunke002
I want to throw in some extra tweeters in the front, and I've decided that by far the easiest way would be to hook them up directly to the speakers that are already in the door which are powered by a 4 channel amp. The amp delivers 50 watts per channel at 4 ohms (my door speakers are 4 ohms), but if I introduce tweeters into the mix will it change the ohm load or is this a good way to hook up tweeters? I have no idea what impedance my tweeters will be, or which ones I should be shopping for. It's all in the process at the moment.
I remember from reading sub wiring diagrams that when you introduce a second sub it changes the impedance load, will the same thing happen if I wire up a tweeter from the speakers terminals? Thanks!
