prochobo
Sedan Sleeper
Been looking for some and I'm seeing a lot of the hood pins which I like. The installation seems easier, but are there any downsides to using the pins?
yea, not like batterys, battery dissconnect, alarm horns, and alarm wires arent under there or anythingRice unless you have something worth protecting underthere. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Will do. . .Please start posting in the correct sections //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Positive and negative battery cables. . . so nobody can simply pop the hood and cut the power to my alarm. I have a battery backup, but overkill is good.Rice unless you have something worth protecting underthere. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well, that's not what I intend these for. You can pop the hood from the inside, but the hood won't open unless you unlock the hood locks which will require a key or a hell of a lot of force.If you can figure out how to pop the hood from the outside with out first poping up the release lever you are one hell of a theif.
Control box? The brain right //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif ? It's impossible to get to without setting the alarm off.Ok, so if they can get into the car without setting off the alarm why would they need to get to the hood to cut the power? Why not just locate the controll box and unplug it?
Well, that's where the hood lock comes in, so they can't pop the hood. In the event that the power does get cut, the battery backup will kick in along with a battery backed up siren. I don't want to get into the specifics of my alarm, but if a theif can successfully yank my brain out without setting anything off. . . he's got balls and skill //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gifYou can snip the power wire to it, unplug it, what ever. If they can get into the car with out setting the alarm off, then pop the hood with out setting the alarm off they could get to the "brain" and not set it off. Hell if they are that good they could remove your equiptment and **** your girl friend with out setting the alarm off.
